engine stalled while driving/won't restart!!
Old Sep 14, 2003 | 10:29 PM
'01whiteSS's Avatar
Just what the post says...On Friday night, I was accelerating hard onto the freeway, and I had just shifted into 2nd gear and all of a sudden, the engine just turned off!! I tried to restart it while the car was still moving and it wouldn't. I coasted it to the side of the freeway and continued to try to restart with no luck (the starter works fine but the engine wont turn over). I had to get it towed back to my friend's house. I went back the next day with one of my friends (who knows alot about working on cars, and is actually the one who just did my motor swap for me, etc) to take a look at the car. He checked for a spark and found none, and he thought it might be the ignition coil or the ignition control module. I replaced the coil, and it didn't fix anything, so I took the control module to an auto parts store to have it tested, and they said it was working fine. So, what's next?? Is it most likely my optispark?? Any info is appreciated-Thanks!
Old Sep 14, 2003 | 10:33 PM
Smoke T/A's Avatar
Sounds like the ICM is not right. Gm didn't place it in the most convienient place right up against the head. If it was the opti usually you would have some indication it was going out first.
Old Sep 15, 2003 | 06:28 PM
'01whiteSS's Avatar
I suspected the ICM, but I took it to a local auto parts store to have it tested with their meter, and they said it was fine.
RUENUF
May 25, 2016 08:10 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Injuneer
Dec 15, 2014 09:36 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
