engine squeak
engine squeak
Hi Guys. Changed my water pump and serpentine belt about 2 wks. ago. Yesterday I began hearing an engine squeak that sounds like an accessory bearing . The noise increases w/ engine rpm. After the car has been driven for 5 minutes or so the noise goes away. Always comes back again after starting "cold" engine. Always goes away after running 5 min. or so. Put on some belt dressing w/ no results. Squeak is not a schrill type squeak. What do you guys think is going on! Thanks a lot guys! Larry
Caps94ZODG
22
Jul 30, 2002 08:45 AM
