engine squeak
Old Jul 17, 2005 | 07:03 PM
llwta's Avatar
engine squeak
Hi Guys. Changed my water pump and serpentine belt about 2 wks. ago. Yesterday I began hearing an engine squeak that sounds like an accessory bearing . The noise increases w/ engine rpm. After the car has been driven for 5 minutes or so the noise goes away. Always comes back again after starting "cold" engine. Always goes away after running 5 min. or so. Put on some belt dressing w/ no results. Squeak is not a schrill type squeak. What do you guys think is going on! Thanks a lot guys! Larry
Old Jul 17, 2005 | 07:17 PM
llwta's Avatar
Re: engine squeak
Forgot to mention this is a 95 T/A. Larry
Old Jul 18, 2005 | 09:01 PM
llwta's Avatar
Re: engine squeak
No ideas guys?? I'm beginning to think that I may have bad water pump bearing! But why does it always go away after running 5 minutes. Larry
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
RichJ
Sep 26, 2002 09:43 AM
Christopher
Sep 14, 2002 03:08 AM
rod442
Aug 26, 2002 01:22 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
