Engine Smoke?
Old Jul 4, 2006 | 05:06 PM
Moshbmx1's Avatar
Engine Smoke?
My engine started to smoke out of what looks like between the heatshield and the header on the passengar side. Doesnt smoke bad and isnt very thick of a smoke screen. The engine has normal oil pressure and doesnt sound like it has any problems inside, just normal ticks. It seems to leak alittle more oil then usual but i cant tell where it is coming from. Valve cover gasket? Or? Anyhelp?
Old Jul 4, 2006 | 07:59 PM
OBE1 95Z28's Avatar
Re: Engine Smoke?
If you're dripping any oil on that header, that will create smoke. I'd check the valve cover gasket first.
Old Jul 4, 2006 | 08:47 PM
1racerdude's Avatar
Re: Engine Smoke?
Check the back of the intake.
Old Jul 5, 2006 | 08:18 PM
Moshbmx1's Avatar
Re: Engine Smoke?
Anyone had an overflow of oil out of the hose on the passengar side valve cover? The hose that goes from the cover to the TB.
Old Jul 5, 2006 | 08:30 PM
1racerdude's Avatar
Re: Engine Smoke?
Normal to have oil in the intake. If ya don't want it put an inline fuel filter on it and lay on the injectors and plug the hole in the TB.
MattFick
Feb 15, 2015 10:16 PM
dale3in98
Feb 14, 2015 12:18 PM
blac94Z
Jan 12, 2015 05:44 PM
Noenav
Dec 6, 2014 07:35 PM
Redbird
Jul 28, 2002 12:03 PM
