Engine shutoff at 100mph! LT1 experts help!
Old Mar 21, 2007 | 12:18 AM
emerica4601's Avatar
Whats up guys ...
JUST LITERALLY got the new cam and valvetrain installed by hsw. They heat cycled it and told me I was good to go if I wanted to beat on it a bit.
Heres what happened:
Got on the turnpike and saw an open stretch .. so decided to punch 3rd. I tached out 3rd at 6300 and tapping the rev limiter (not knowing where it was ... first time driving car with cam). Then shifted into 4th and punching it for a solid second then POP POP POP POP POP. Engine shuts off.
I tried to start her back up, and it popped a bit and wanted to turn over, but never did. Keep in mind that I just got a brand new gm heavy duty timing set put on.
Possible problems?:
fuel pump/filter went out? (is stock)
engine flooded when I hit the rev limiter?
something else??????
HELP ME!
Old Mar 21, 2007 | 12:27 AM
bowtiethunder's Avatar
could be your opti, some have problems spinning them high.
Old Mar 21, 2007 | 12:36 AM
Z95m6's Avatar
That is my first guess. I'd check and see if you have spark.
Old Mar 21, 2007 | 12:57 AM
j0n's Avatar
j0n
same thing happened to me when i grenaded my first opti...i was somewhere around 6k rpms in 2nd on an on ramp when it studdered and died. when i pulled the opti apart the rotor had exploded into 43 pieces
edit: scan for codes...mine popped the opti code
Old Mar 21, 2007 | 01:10 AM
LiENUS's Avatar
You counted?! and people accuse me of being ocd
Old Mar 21, 2007 | 01:11 AM
Javier97Z28's Avatar
Moderator
I'd say your opti blew apart.
Old Mar 21, 2007 | 01:12 AM
j0n's Avatar
j0n
lol nah it was sarcasm...but it was at least that much after i got done with my ball-peen hammer
Old Mar 21, 2007 | 01:14 AM
LiENUS's Avatar
I love ball-peen hammers. I have 3, 2 small and 1 big. In fact I am currently in the process of making a sword with a ball-peen hammer. They're also great wrapped in cloth for getting rid of minor body-dents in metal bodies.
Old Mar 21, 2007 | 01:39 AM
j0n's Avatar
j0n
ooooooh found a pic of my opti dissasembly
Old Mar 21, 2007 | 01:52 AM
Moderator
We lit my blown up opti on fire
Old Mar 21, 2007 | 01:53 AM
racer96's Avatar
hey man the exact same thing when i had my comp cam put in. i had it put in by a gm mechanic and he didnt realize the cam dowel pin was to long bolted the opti up (wasnt even flush). screwed the opti just like that. took about 20 miles. driven down the highway to pass a car pop pop pop backfire, shutoff just managed to manhandle the steering wheel in before ghetting hit by a semi truck. true story guys it was scary. but that was what was wrong with mine.
Old Mar 21, 2007 | 07:06 AM
I got only 33 miles out of her before this happened. hsw knows what their doin .. id be surprised if they messed up the cam install when it comes to the dowel pin on the cam ...
Old Mar 21, 2007 | 07:38 AM
IXLR894Z28's Avatar
I'd opt for the opti (no pun intended )
Old Mar 21, 2007 | 08:11 AM
Z-RATED94's Avatar
Don't worry, that's nothing that hammer and a little super glue can't fix.
Old Mar 21, 2007 | 08:47 AM
pcgamer4life's Avatar
Stop whining, that'll buff right out!
