Engine shut down after going over a bump
Old Mar 31, 2007 | 11:48 AM
balls51's Avatar
it was a large bump, engine died poped a couple of times then died, now it wont start but sounds like a cylinder or 2 or trying to fire, what the hell happened, please help
Old Mar 31, 2007 | 12:02 PM
balls51's Avatar
oh
94 ta lt1 auto
Old Mar 31, 2007 | 12:05 PM
mrmint69's Avatar
It sounds like something came disconnected. I just read where someone hit the cat on a curb causing the thing to be plugged where the car would not run. This one may be hard to figure out. Did any part of the car hit the bump?
Old Mar 31, 2007 | 12:14 PM
balls51's Avatar
nope
i was driving down the road, doing about 55-60, i didnt notice a drop in the road, it kinda launched me, then the car quit, now when i go to start it, sounds like a cylinder or 2 are fireing but wont start,
Old Mar 31, 2007 | 02:53 PM
mrmint69's Avatar
I would start with a fuel pressure test and the make sure you have spark. I can only think to try the easy stuff and eliminate them first. My best guess is something got jarred loose and now the passage way is blocked or something is broken.
Old Mar 31, 2007 | 03:32 PM
97greenie's Avatar
I read on another board once that the same thing happened to someone.It turned out that the jar from the bump killed his fuel pump.Sounds unlikely but stranger things have happened.
Old Mar 31, 2007 | 04:05 PM
balls51's Avatar
ok
ok i had a mechanic whos a bud of mine come over, we have spark and it sounds like the fuel pump is working. But ill check that. Thanks for all the info, if i find out what happened ill post, gonna start to really tear into her tonight.
Old Mar 31, 2007 | 04:12 PM
balls51's Avatar
also
if u can think of anything else please lmk
thanks,
Old Mar 31, 2007 | 05:02 PM
2000GTP's Avatar
I'd go over all the connections again. Is it just the motor that doesn't start, or are other accessories not working as well? I would also look over the power and ground blocks on the passenger shock tower.
Old Mar 31, 2007 | 08:57 PM
jclark311's Avatar
Check the safety switch for the fuel pump, its there in case you get in an accident, so fuel doesnt keep pumping.
Old Mar 31, 2007 | 10:25 PM
LiENUS's Avatar
Is the exhaust manifold heating up when you try and spin it over? (Don't test with your hands) and if one is are both? also check all your fuses you might have just shorted something and blown a fuse in the process.
Old Mar 31, 2007 | 11:12 PM
balls51's Avatar
hmm
all electronics work, where the fuel shut off switch,
thanks for the replies cant find anything yet, could the timming gotten messed up
Old Apr 1, 2007 | 12:33 AM
balls51's Avatar
ajsdflj
headers does warm up a little bit when I turn it over, i wonder if she jumped timming or something happened with the opti.
Old Apr 1, 2007 | 02:03 AM
j0n's Avatar
j0n
I experienced the same symptoms when the 2 screws that hold the rotor to the optispark backed themselves out. I was at 4k rpms and sideways when it happened, the car died and upon attempting to start it the car sounded like 1 cylinder was firing. I pulled the opti apart, loctited the rotor screws, put it back together and never had another problem.
Old Apr 1, 2007 | 10:49 AM
balls51's Avatar
tested
i have spark about 1 spark per second when cranking, after cranking on it a little bit the headers do get warm not hot but warm. so thats prolly not the opti. this is becoming a head banger, how much presure should i have for fuel. anything else i should check. i was getting ready to pop the water ump off to check the opti.
