engine runs better with ses light on????
Old Dec 9, 2004 | 11:30 PM
95camaro3400's Avatar
ive had my 97 z28 m6 with 100k miles for about 2 weeks, about 2 days after i got it i noticed a bad miss with moderate acceleration, i changed plugs and wires and nothing changed now tonite my ses light came on and it runs great , no miss at all, any ideas?
Old Dec 9, 2004 | 11:34 PM
dmoor88's Avatar
Re: engine runs better with ses light on????
running in open loop?
Old Dec 9, 2004 | 11:44 PM
thtas what i was thinking how can i tell if my car is running in open loop and does this rule out an ignition problem?
Old Dec 10, 2004 | 12:56 AM
BigBlue95Z's Avatar
Could be a number of things. Any enginge performance sensor(o2, maf, ect) that is going bad will give you poor performance from bogus readings. When the SES light comes on, the computer ignors the values from that sensor and the computer goes to a preset value for that device. That value is obviously better than what the sensor is putting out to the computer. Thus, your car seems to run better.
Get that code scaned to see what is causing it. Could be o2, maf, ect.
Old Dec 10, 2004 | 06:16 PM
96capricemgr's Avatar
Harbor Freight sells a basic OBD2 scanner for $40 it will help you figure out which sensor the pcm is ignoring, which I agree is what is happening.
Old Dec 11, 2004 | 12:41 AM
Spinner's Avatar
Open loop, set tables, probably either a MAF or an O2 sensor issue.
Old Dec 11, 2004 | 11:07 PM
chrism400's Avatar
O2 sensor is my guess. My car actually ran better when the SES light came on too. I removed the O2's on both sides and the car ran great. With them, it would miss badly in closed loop.
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Lions3
Apr 11, 2003 10:55 AM
Rich_z28
Sep 13, 2002 03:35 PM
MJ_Z28
Aug 7, 2002 07:15 PM
