Engine Removal, Quick Question
Old Jan 29, 2011 | 12:53 AM
  #16
SkiBumDreams's Avatar
Re: Engine Removal, Quick Question
heres my thread about the same subject
https://www.camaroz28.com/forums/sho...d.php?t=587100
Old Jan 29, 2011 | 06:57 AM
  #17
Rich2279's Avatar
Originally Posted by Injuneer
A4 or M6? Do you mean unbolt the bellhousing from the engine? Tilt tailshaft down, being careful not to force the oil pressure sending unit into the cowl. You can push up gently on the front of the engine to tilt the tailshaft down more.
A4 trans. Yes, the housing bolts are hard to get leverage on them. I tried removing the upper bolts w/ a wrench. So, I need to remove the driveshaft, unbolt torque arm, and trans mount to tilt it back?
Old Jan 29, 2011 | 09:29 AM
  #18
1badasZ's Avatar
Originally Posted by Z28Roxy
K-member is 3 bolts on each side, very easy and you don't even have to get under the car to take them out.
Intake does not have to come off until it's out of the car.
Hood does not have to come off, neither does the bumper.
after doing so what do you hook to on the car to pick the car up?
Old Jan 29, 2011 | 09:52 AM
  #19
RamAir95TA's Avatar
http://www.michiganspeed.com/enginepull/index.html
You hook the straps/chains to the two front frame rails.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
