Engine rebuild pics 56k beware
Old May 2, 2008 | 01:18 PM
  #31
bombebomb's Avatar
Originally Posted by Pezcore67
was it hard pulling it from the top? I know the proper way is to drop cradle engine/tranny as an assembly. I considered pulling mine from the top.
Was easy enough, had good mechanics though.
Old May 2, 2008 | 02:12 PM
  #32
OutKast's Avatar
pulled mine from the top a few weeks ago but I went ahead and removed the heads first. Pretty easy but I've also done it from the bottom and it seemed to go a little quicker. All depends on your facilities.
Old May 2, 2008 | 02:16 PM
  #33
Dave1980's Avatar
Originally Posted by bombebomb
Yea, im looking at the racetronix injectors on thunder racing. I believe this is what I need 135-INJ-621031-8 Delphi/Lucas 42# High Impedence Fuel Injectors, Am I correct? Anyone wish to chime in on the cam yet? I know theres 500million topics under search for cam stuff, and it never seems like they have an exact topic asking my questions lol.
I went with the racetronix plug/pump harness/42lb delphi lucas setup. It seems to be the easiest for plug and play.
Old May 2, 2008 | 03:29 PM
  #34
n2omike's Avatar
Did mine the same way also removed the heads first.... wasnt bad.
Old May 2, 2008 | 05:53 PM
  #35
bombebomb's Avatar
Looks like ill prolly be going with the lunati cam.
Old May 4, 2008 | 09:19 PM
  #36
bombebomb's Avatar
This may be a dumb question, but does anyone know where I can get a specific lt1 gasket kit, with felpro 1087 head gaskets (.039 compressed height) I found one on summit, but its bore is 4.125(yes I know why the hell would they even make a 4.125 gasket for an lt1) Anyones if someone has a recommendation shoot it out. Im looking at our vendors etc now, already checked jegs and summit. Also will I be needing different lenght push rods for the new cam? Looks like a found one from victory racing!
Old May 5, 2008 | 10:41 PM
  #37
bombebomb's Avatar
Small update, got my ac delete pulley in today
Old May 6, 2008 | 03:35 PM
  #38
bombebomb's Avatar
I have a question about gasket sets. Since I am going .030 over will I need a gasket set that has a .030 over head gasket? Thanks.
Old May 6, 2008 | 03:55 PM
  #39
Rising Phoenix's Avatar
No the headgaskets are the all the same, 4.125 bore.
Old May 7, 2008 | 02:19 AM
  #40
bombebomb's Avatar
Oh, thank you that explanes the 4.125 bore head gasket then
Old May 8, 2008 | 09:13 AM
  #41
Z-RATED94's Avatar
You really should at least get the heads pocket ported and a good valve job. You going to have them milled to make sure their flat?
Old May 9, 2008 | 06:18 AM
  #42
bombebomb's Avatar
They will be getting a valve job and im sure whatever has to be done the builder will know to do it. But in a direct anwser, I do not know.
EDIT: received my AIR/EGR blockoffs from rdspeed yesterday.
Old May 13, 2008 | 03:44 PM
  #43
bombebomb's Avatar
Got crank,piston rings (nitrous hardened rings), bearings(h-series) today. Will post pictures soon. Aswell as my intake with block offs. Is it normal for the bearings to have like a "file" mark through them, one of mine does and im not sure if thats normal.
Old May 13, 2008 | 05:32 PM
  #44
pcgamer4life's Avatar
While you've got that intake off, get it sandblasted... or paint it
Old May 13, 2008 | 05:34 PM
  #45
bombebomb's Avatar
I was thinking about just leaving it as is and make it look stock. Painted would be tempting though.
