Engine rebuild pics 56k beware
Old Apr 10, 2008 | 05:31 PM
bombebomb's Avatar
Plan is 383, je nitrous piston, compstar 6" rod, 3.75 compstar crank, lunati 60122 cam, stock heads for now. 12:1 compression, 300shot nitrous.
Here are the first pics of us taking it out, there basicly in order.
Old Apr 10, 2008 | 05:33 PM
bombebomb's Avatar
88 tracer motor random photo during tear down
Old Apr 11, 2008 | 12:27 AM
Dave1980's Avatar
When I pulled mine and looked at the harness laying there in the engine bay, I was thinking hmmmm ,that should be fun to hook back up later.
Old Apr 11, 2008 | 01:16 AM
bombebomb's Avatar
I labled many of the plugs, and most of them should be easy to put back in place. Will see though, waiting on engine builder to call.
Old Apr 11, 2008 | 01:59 AM
ssbowtie1's Avatar
Don't use fram oil filters.
Old Apr 11, 2008 | 09:19 AM
OutKast's Avatar
99% of the plugs are different so it's not as bad as you might think. Any plugs that are identical are likely going to be in completely different areas of the car.
Old Apr 11, 2008 | 12:43 PM
My Red 93Z-28's Avatar
I was going to post this as well...lucky your engine lived as long as it did
Old Apr 11, 2008 | 01:18 PM
reamo04's Avatar
nice to see somebody pullin it out the top
Old Apr 11, 2008 | 01:21 PM
That's how I did mine as well
Old Apr 11, 2008 | 01:24 PM
reamo04's Avatar
also, why only a 503 in a 383? thats going to be a REALLY tame setup
Old Apr 11, 2008 | 03:16 PM
bombebomb's Avatar
Yup, im going to wix.
Im not sure if I should go with cc503 or not, ima ask my engine builder.
I did not think out the top was that bad.
Old Apr 11, 2008 | 03:19 PM
reamo04's Avatar
yeah
for a cam, i would look into like the lunati 1022
http://store.summitracing.com/partde...2&autoview=sku
Old Apr 11, 2008 | 03:23 PM
bombebomb's Avatar
yeah
I take a look at it, im going to drive it on the street, but its a toy so basicly a strip car lol.
Old Apr 11, 2008 | 04:01 PM
96capricemgr's Avatar
When you say stock heads you mean as cast or ported??
I understand doing a shortblock as a repair and not being able to afford head work but just wanted to tell you a 300shot and as cast heads is not going to work.
I have seen a car gain nothing from a 175 to 200 shot because the heads could not flow enough to let it work well. Start spraying big shots without suporting flow and it displaces a huge amount of the NA flow and chokes up on the exhaust side and you stop gaining much if anything even though you put in bigger jets.
Old Apr 11, 2008 | 06:40 PM
bombebomb's Avatar
You have a valid point (or it makes sence to me anyway), nitrous is not going on yet, the heads will most likely be stock cast for now. Anyone want a dented fram oil filter has 89 miles on it lol jk.
