Engine Rebuild - Hoses, fittings, etc
Old Feb 16, 2004 | 12:31 AM
zachattack45's Avatar
I have just gotten my engine taken out of my 95 trans am and had my car towed back to my house. I am in the process of cleaning up the engine bay and realize that i will probably need to replace most of the hosing and such. Does anyone know the best way to get this stuff? Is it all available online? Also there is a little red box right above the batter that has wires going into it and its falling apart. Need to get a new one of those but done know what is. Can anyone help with this sort of restoration?
Old Feb 16, 2004 | 05:36 AM
Mtrhds94Z's Avatar
The Goodyear Hi Miler hose kit is good, for 95-7's [from Summit etc for about 99 bux..]
It is missing one hose, but that can be made up with a piece of 3/4" heater hose..
Dremel the clamps off of the heater hoses, and replace with the new hoses..
It's a nice kit for the price..
The red junction box on RH shock tower is GM p/n 12186586
Old Feb 16, 2004 | 08:16 AM
great, tht kit comes with radiator hosing and everything but heater hosing correct? Also the pin number on that part, where do i get it from?
Old Feb 16, 2004 | 09:26 AM
SWINGRRR's Avatar
www.gmpartsdirect.com
Old Feb 16, 2004 | 10:20 AM
Cool, is there anything else worth replacing at this point? still have then engine out.
Old Feb 16, 2004 | 10:31 AM
Flush your heater core while the engine is out.
Old Feb 16, 2004 | 10:35 AM
Alright, but is there any parts i should get to restore it? Had 128k before i took the engine out.
Old Feb 16, 2004 | 12:28 PM
Like hosing, fittings wise. Stuff thats in the bay that i should replace.
Old Feb 16, 2004 | 02:28 PM
Mtrhds94Z's Avatar
It comes with all but hose #15 on this diagram from shoebox' site:
http://shbox.com/1/heater_hoses.jpg
Heater hoses 3,7,12,17,20 are included [need trimming to fit] hose 15 can be made up with a piece of regular 3/4" heater hose.. [note there are 6 heater hose sections total, 5 are in the kit]
For the missing #15 hose, I used, instead, a piece of '3/4" heater hose', cut to about 14 1/2" [the p/n for a GM replacement hose for that is: 'heater inlet front hose' GM p/n 10146991
Radiator hose wise, all hoses in this diagram:
http://shbox.com/1/95-97_hoses.jpg
1,4,5,14,16, are included.. The Goodyear is a good kit for 100 bux.. I changed my 94 to the later 95-7 configuration with it[ I feel it's a better setup..
Just cut the swaged aluminum clamps [carefully! don't cut the aluminum tube that's under the hose] off of the heater hoses, and use regular stainless spiral type hose clamps..
I found cutting partway thru, making a little slot in the clamp, then use a flat screwdriver and twist it in the slot, it breaks easily then..
If you have done TB bypass, you won't need hose #4
It doesn't come with the radiator overflow hose either..
Goodyear kit p/n is # 5006
Old Feb 16, 2004 | 02:30 PM
where would i get the stainless spiral clamps?
Old Feb 16, 2004 | 07:18 PM
Mtrhds94Z's Avatar
I mean the common hose clamps that everyone uses.. [i call em spiral hose clamps] that are like a worm gear screw that engages slots in the band of the clamp?
Very common.. Home Depot a hardware store etc..
Old Feb 16, 2004 | 08:19 PM
bigde4u's Avatar
Isn't that hi miler hose kit blue? I need new hoses myself but i don't think blue would go well with my black and red.
Anyone know of where i can get some hoses that aren't blue?
Does gm parts direct sell them?
Old Feb 16, 2004 | 10:32 PM
yea im trying to find them not in blue, i dont think tis gonna happen, gonna have to put covers on them i guess.
Old Feb 17, 2004 | 05:48 AM
Mtrhds94Z's Avatar
All Hi Miler hose sets are blue.. they are 'EDP' a longer life rubber compound..
Guess you could pop for GM hoses[bring bux]
Old Feb 17, 2004 | 08:12 AM
I see. Anyone know where to get some dress up stuff cheaper then MBA?
