engine problems
Old Aug 4, 2006 | 04:40 PM
  #16
1racerdude's Avatar
Re: engine problems
Originally Posted by Daniel6718
so you think i need to turn the flywheel? or the pp?
Don't know,but ya need to first check to see if it's clocked right.
Was the engine balanced?
Was it internal balanced?
Was it balanced like factory with the front half internal and the back half external?
Was the balancer and flywheel balanced with the internals?
Was the PP balanced with the internals?
Is the PP clocked right?
If the engine was balanced internally and the flywheel was not balanced with it,there is your problem. From the factory it has a weight,and if the engine was internal balanced it don't need the weight. Ya should have it "0" balanced. Maybe just taking the weight off will do it,but to be correct it should be "0" balanced.
Old Aug 4, 2006 | 07:02 PM
  #17
Daniel6718's Avatar
Re: engine problems
well mayb i can give you more info...this motor was from a guy that had a spun bearing i had it rebuilt no balancing or nothing...(i did this to my other z28 also) i have had no problems with my other car its been up for 2 years now, the differance is i used the same motor taht came out of my car...this motor is from a diff car and it was bone stock...so it shoul-d be stock neutral balanced, which means all that i shoulda had to do was have the flywheel zero balanced correct? mayb that will give more info
Old Aug 4, 2006 | 07:17 PM
  #18
1racerdude's Avatar
Re: engine problems
If it's stock it is half and half front is 0 balanced(internal) and the back has a weight on the flywheel(external). If for some reason the weight is off it ain't balanced.
Old Aug 4, 2006 | 11:07 PM
  #19
Daniel6718's Avatar
Re: engine problems
ok then i found it...i talked to hte prevous owner of the tranny/car and it has been zero balanced...i posted another thread already asking hwo to fix it...i guess i might try my luck with another stock lfywheel if i can find one...if not i dont wanna have to tear the motor down to get a friggin flywheel balanced to the crank...any ideas? whats the easiest REALIABLE fix??
thanks for the halp anyways! i apprietiate it! you seem to be the only1 chiming in
Old Aug 4, 2006 | 11:19 PM
  #20
1racerdude's Avatar
Re: engine problems
If it's internally balanced try taking the weight off of the flywheel.
If that don't work then get another FW and have it "0" balanced and bolt it on.
Ya shouldn't have to take anything else but the FW to the shop.
Old Aug 5, 2006 | 02:00 AM
  #21
Daniel6718's Avatar
Re: engine problems
its not internally balanced...BUT THE FLYWHEEL IS ZERO BALANCED SO SOMEHOW I NEED A FLYWHEEL BALANCED TO A STOCK LT1 OR TO GET THIS ONE (WHICH ID PREFER) BALANCED TO IT
btw sorry for the caps...
Old Aug 5, 2006 | 02:14 AM
  #22
1racerdude's Avatar
Re: engine problems
Like ya said get one out of the salvage yard and bolt it in. Should fix it.
edman
Jan 25, 2015 02:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
