engine problems
Old Feb 23, 2004 | 11:20 AM
Jeremy_30th's Avatar
Angry engine problems
Hey guys I recently did some work to my car heads, intake, cam, lt headers and some other little things. Here is my problem every so often the car will stumble, or miss . Here is my theory I have topped off my coolant several times after the work and it is low again I think that it is leaking into the engine and burning off during combustion most of the time or creating a miss fire when to much.. also we just had a very nice day out and no cars were smoking from the exhaust except mine a steamy white smoke which futher leads me to this conclusion.. Thanks for your help
Old Feb 23, 2004 | 11:56 AM
Your theory is probably correct. Look at the plugs. Ones burning coolant will usually be cleaner and a lighter color.
Old Feb 23, 2004 | 11:58 AM
yeah i pulled a couple and they were a whiteish burn to them ... they should be more tan in color right ?
Old Feb 23, 2004 | 12:05 PM
As rich as the LT1 runs, they are usually quite grey (more on the darker side of the spectrum). You might pull a few more to compare.
Old Feb 23, 2004 | 12:07 PM
thanks for the help
Old Feb 23, 2004 | 01:29 PM
i pulled all the plugs except 1,7 and 8 and they all had same color "whiteish" if thats a color ... do you think its possible it could be one of the three i didn't pull ? or maybe the color i'm observing is from small leakage into them all... my thought is there is no leakage on the ground so it has to be...
Old Feb 24, 2004 | 05:21 AM
slopokrodrigez's Avatar
Have you checked the oil for coolant? Is there oil in the coolant? Have you pressure tested the cooling system? Can you do a leak down test? All these can help you determine where the leak is occuring.
Old Feb 24, 2004 | 05:27 PM
Thanks to all for comments and help...today i had the cooling system pressure tested and there was a drop in pressure also the guy agreed there was a detection in the exhaust as well..thanks again
edman
Jan 25, 2015 02:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
