engine mounts
Old Feb 21, 2010 | 01:53 PM
sa7eral3ain's Avatar
engine mounts
i have 97 z28. my question is: what is the simplest way to change engine mounts?? do i need to raise the engine up??
Old Feb 21, 2010 | 03:49 PM
You have to push up on the bottom of the engine to take the weight off the bolts that go horizontally through the upper and lower portions of the mounts. You don't have to "lift" the engine, just support the weight on a heavy piece of wood, jacked up against the bottom of the pan, and off the bolts in the mounts. To pull the long bolts forward out of the mounts, you will need to turn the steering wheel to full lock, to get the linkage out of the way of the bolts.
Parts Wanted
Mar 17, 2015 11:24 PM
Jason Short
Jan 19, 2015 06:34 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
