Engine monitoring system...
Old Jul 12, 2004 | 03:35 PM
Heatmaker's Avatar
Advanced Member
does nayone make and engine monitoring system for these cars?
Old Jul 12, 2004 | 04:01 PM
Red96Lt1's Avatar
Are you talking about a scanmaster ?
Old Jul 12, 2004 | 04:12 PM
simple's Avatar
underhood camera for surveillance ebay has'em cheap
Old Jul 12, 2004 | 04:20 PM
If you had a signature with some useful info in it, people could tell you exactly what systems are available, but without that info, no can give you the correct answer.
Just a thought.
Old Jul 12, 2004 | 06:38 PM
Heatmaker's Avatar
Advanced Member
I was just woindering... been peaking under some hoods... and started checking out those Apexi things that have the live fuel curve data in them... throttle response... allot of stuff.. was wondering if anyone had something like that for our cars... so you can check out the fuel curves... engine codes ETC... The SES light isn't even worth looking at anymore... when there is a problem you can't tell...
Old Jul 12, 2004 | 07:08 PM
disco192's Avatar
Freescan, datamaster, autotap
Old Jul 12, 2004 | 10:19 PM
Heatmaker's Avatar
Advanced Member
are those on board systems?
Old Jul 12, 2004 | 10:57 PM
DonHood's Avatar
Scanmaster = on-board, on all the time, and monitors pretty much everything that the PCM has connections to.
Old Jul 12, 2004 | 11:13 PM
Heatmaker's Avatar
Advanced Member
How acurate are those?
Old Jul 12, 2004 | 11:39 PM
ibanez6rg's Avatar
As accurate as the sensors are.
Old Jul 13, 2004 | 01:19 AM
disco192's Avatar
The only sensora that arent very accurate are the o2 sensors. They basically just tell you lean/rich. It wont tell you the exact AFR. If you are OBD1 with a laptop, you can get the software free and the cable for $95.
Otherwise, you can get autotap for $200
armedtrigger
Feb 24, 2015 08:30 PM
97FormulaWS-6
Sep 11, 2002 11:57 AM
squirrels
Jul 13, 2002 01:58 AM
CAJUN-Z
Jun 20, 2002 08:56 AM
