engine knocks at shift point
Old Mar 5, 2007 | 08:38 PM
cleangene's Avatar
Ok I got a engine knock which occurs right at the shift points, if you hold the car in first or second and let the engine tachs up say 3k, hold it there steadie you get a knocking noise, it does this in every gear, once it changes gear the noise goes away untill it tachs up again, you don't hear the noise when reving up the engine, only before the shift points, I think it's a rod bearing bad but not sure, it's been a long time since I hear a rod knocking.
jb4xx
Feb 2, 2015 10:00 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
