Will a Gen I block work with lt1
Old Mar 5, 2007 | 07:10 PM
Black 97 SS's Avatar
Will a gen I 4 bolt block work with LT1 heads, Opti Waterpump ETC. My buddy has a couple not in use and said i could have one for my camaro if they could be swapped.
Old Mar 5, 2007 | 07:19 PM
Another Red Z's Avatar
No totally different , only some of the internal parts are the same . The motor will fit but will not work with the stock electronics .
Old Mar 5, 2007 | 07:47 PM
LiENUS's Avatar
Check advanced tech, someone was looking into converting a 400 sbc to lt1 injection, It would take a lot of work though.
Old Mar 5, 2007 | 07:52 PM
The Engineer's Avatar
The water jacket in the block and heads (reverse coolant flow) including the water pump is the major difference.
WD
Old Mar 5, 2007 | 08:45 PM
2000GTP's Avatar
More trouble then it is worth, just find an LT1 block if possible.
Jeff1904
Jan 3, 2015 12:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
