engine idle too low
Old Mar 19, 2008 | 06:12 PM
william smithjr's Avatar
engine idle too low
frequently while starting my 93 z28 the engine idle will set way below 1000 rpm.other times it will set normal, what is the problem.
Old Mar 19, 2008 | 06:53 PM
dangalla's Avatar
could be a lot of things
vacuum leak, IAC (idle air control motor)
Old Mar 19, 2008 | 07:30 PM
mrmint69's Avatar
How does it run the rest of the time? Dirty air filter, restricted air vent or idle passage, faulty opti, air leak, tps or possible engine issues. A torn intake elbow can cause idle issues.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
camy 1993
Feb 3, 2015 06:26 PM
edman
Jan 25, 2015 02:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
