engine harness wire unplugged, what is it?
Old Mar 3, 2007 | 03:37 PM
dfa_crunch's Avatar
found a plug underneath my air filter unplugged and taped off with electrical tape, cant find where it could plug into, black and purple wires with a plastic heat shield over it? anyone know?
Old Mar 3, 2007 | 05:33 PM
DR.ZED's Avatar
Near the ABS motor? Maybe the wiring for the air pump.
Old Mar 3, 2007 | 06:11 PM
dfa_crunch's Avatar
you know, this would make sense because the AIR has been removed from the car by the previous owner, and i do have the DTC for the AIR circuit
Old Mar 3, 2007 | 06:12 PM
DR.ZED's Avatar
Odd.... I NEVER got a DTC for the air circuit in my 94 and mine is gone as well.
Maybe the owner took the AIR fuse out as well? I would check that, and put a fuse in.
Old Mar 3, 2007 | 06:18 PM
dfa_crunch's Avatar
fuse is in and its good, i actually posted about this before. if it is that sensor then thats cool. just making sure its not something important. that DTC shouldnt do any harm to my car so i have just left it because i was unable to figure it out
Old Mar 3, 2007 | 07:12 PM
DR.ZED's Avatar
Not a sensor per se, the connection to the pump itself.
Interesting how you have a code, and I don't. Anyway.
Old Mar 3, 2007 | 07:19 PM
dfa_crunch's Avatar
well yea not the sensor, but the code calls for faulty circuit
Old Mar 3, 2007 | 11:53 PM
The diagnostic only checks the connection to the relay. If the fuse is good, you will not get a code in OBD-I. Check the fuse again.
Old Mar 4, 2007 | 12:10 AM
dfa_crunch's Avatar
will do. but is this confirmed that thats the wire from the AIR or are you saying that the AIR didnt have a connection. i also found this
http://i5.photobucket.com/albums/y17...0303071642.jpg
that connector there did not seem to match up to the loose plug i had originally asked about, that picture was taken from underneath on drivers side. whats that there?
Old Mar 4, 2007 | 12:15 AM
LiENUS's Avatar
Thats air pump stuff, take it off and be sure to reattach the groundwire.
Old Mar 4, 2007 | 12:44 AM
I think you are saying the connector you are asking about is NOT like the AIR connector in the photo you linked???
There's no purple wire connected to the AIR pump. The three wires for the AIR pump are red (2) and black. The only electrical component actually mounted under the stock air filter is the cruise control module.
Old Mar 4, 2007 | 12:51 AM
dfa_crunch's Avatar
and would explain why my cruise control never worked, thanks injuneer
Old Mar 4, 2007 | 10:00 AM
Want a cruise control box? I removed mine.
Old Mar 4, 2007 | 11:06 AM
dfa_crunch's Avatar
thanks for the offer, but i almost fall asleep on the drive to work anyway. nevermind if i actually had the cruise control working
Old Mar 4, 2007 | 04:54 PM
DR.ZED's Avatar
LOL!
... well at the sound of it anyway.
willismoons
Feb 14, 2015 08:42 PM
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
gh0st
Sep 1, 2002 10:24 AM
