Engine harness compatability
Old Dec 3, 2010 | 01:45 AM
Rashiki's Avatar
Can i use an engine harness from an automatic f body in my t-56 equipped car?
Also, what is this 'dual fan' option i keep seeing?
Old Dec 3, 2010 | 06:47 AM
Re: Engine harness compatability
An auto harness won't have all the right connectors for a T56. Better to get the right one, IMHO. All Zs have dual fans.
Originally Posted by shbox.com
There are two versions of the dual fan configuration:
1993-1994 - Primary and Secondary fans that operate at only one speed. When initially commanded on, only the primary fan (driver side) comes on. It operates alone at full speed. If the temp threshold is met for addtional cooling, the secondary fan (passenger side) also is commanded on. At this point, both fans are running at full speed.
These fans use a two relay architecture that can be seen in the fuse/relay panel that is under the hood.
In late 1994 and into 1995, there was a change to low and high speed fans. When initially commanded on, both fans will come on at a low speed. When the high speed temp threshold is met, they both bump up to high speed. A three relay architecture is used for this fan version (seen in the fuse/relay panel). By adding a third relay, low speed can be achieved by running the power to the fans in series. This way, each fan does not get full voltage and runs at a slower speed. High speed happens when the relays switch to provide full voltage to both fans. Low speed is less noisy and should result in greater fan longevity. High speed is not always needed.
Old Dec 7, 2010 | 08:10 PM
Rashiki's Avatar
Thank you.
willismoons
Feb 14, 2015 08:42 PM
Jan 23, 2015 01:13 PM
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
Brian-94TA
Jul 31, 2002 02:52 PM
