ENGINE GURU"S NEED advise!!!!
Old May 22, 2005 | 03:52 PM
LT1CST's Avatar
Hello Fbods Engine builders. I need help on picking my next mod. So far my LT1 355 has went 13.04 at 106 n/a (stock heads)on some crappy Nittos Drag Radials. My car has a PCM FOrless Tune. BUt its not really tuned Yet. SO help me out on my next mod. Im thinking Injectors and Fuel Regulater. OR maybe a TB. Anyway heres a list of my mods. And let me know what you think. IM trying to go mid 12's N/A
Mods
373 gears
2800 stall
1.6 Rockers
612 Vavle springs (combination motorsports)
XE cam 224/236 .555 on LSa 114(CBM)
Jet hot long Tubed Headers
MSD 6a
MSD wires OVC
RAM AIR intake with Functional HOOD
STOCK 48MM TB
STOCK heads
Intake has been ported to match Intake ports to heads
Best ET
in Fontana
13.04 at 106
Old May 22, 2005 | 04:50 PM
marshall93z's Avatar
Re: ENGINE GURU"S NEED advise!!!!
Some good ported heads.
Old May 22, 2005 | 05:29 PM
84 monte SS's Avatar
Nitrous.
Old May 22, 2005 | 05:31 PM
TA2PLAY's Avatar
A real tune, judging by the track times you're leaving an assload of power on the table.
Old May 22, 2005 | 05:59 PM
ZMAN Z28's Avatar
Headers
Old May 22, 2005 | 06:00 PM
LT1CST's Avatar
OH I have those allready. IM sorry I forgot to add that to the list. I knew I was missing something. I have JET HOT LONG TUBES on there
Chris
ttt
Old May 22, 2005 | 09:15 PM
ZMAN Z28's Avatar
Sorry, my bad, I read that as being stuff you wanted to do. hehe. You are in need of some head work. Even a stage 1 would help quite a bit. I'd suggest even more though.
Z
Old May 22, 2005 | 09:19 PM
1racerdude's Avatar
Dyno tune first,then stall,then gear(4.10 but not good in a stock rear) and drive it like ya stole it.Get some tires and tell yourself"it's GONNA leave"
Ya need a port job on your heads.
Call Richard at West Coast cyl head in Reseda (818) 705-5454. They do beautiful work and will tell ya what the scoup is and NO BS.
Several people on the board do good work also--Loyd Elliot is one.
Old May 22, 2005 | 09:49 PM
Luna's Avatar
What are your short times? What is your race weight?
With the 4L60E's steep 1st and a good stall, you will have more than enough multiplication to have traction issues even with 3.23s on Nittos. More tire will probably help since I'm guessing your are cutting a best of only around 1.7 or 1.8s. More gear would be a suggestion if you had a different Turbo400 and more rubber but forget it for now, you obviously have problems hooking (based on your 'crappy nitto' comment.
My suggestion for getting closer, more tire and possibly a little lightening.
After that, have the heads done and real tune. Forget the nickel and dime stuff. They make you go broke and have very little bearing in the long run
-Craig
Sergio
Jan 27, 2016 04:27 PM
nosliw
Feb 7, 2015 01:30 PM
chuyz28
Jan 27, 2015 08:53 AM
squarehead
Jan 15, 2015 07:02 PM
nballisru
Dec 14, 2014 05:01 PM
