Engine grounds
Old May 11, 2008 | 09:51 PM
fastcamz28's Avatar
Engine grounds
How many frame to engine grounds are there on an LT1? I just had a new 383 LT1 installed and the ground from frame to engine (driver's side) was left disconnected (ground strap was broken). Engine builder is in another state. Have talked to them and was told I don't need it. However, my nitrous switches and line lock now don't work. I realize this could be a bad ground, although I have checked it, and it was the same ground site (bolt to firewall inside on driver's side) before engine replacement. All other aftermarket guages, etc are working, including the line lock light. Appreciate any help on this.
Thanks!
Mike
Old May 12, 2008 | 12:42 AM
tapout911's Avatar
Trying to remember off the top of my head... There is one ground that goes to the frame near the abs module that is part of the computer harness. There is also the grounds near the icm off the same harness. Then one off the negative battery to block and finally the one off the starter/knock sensor harness on the passenger side.
Old May 12, 2008 | 10:00 AM
96SilverRam's Avatar
Why would someone say "you don't need that ground" seems like a "I don't care about your problem" statement. Definitely would repair any ground that is not functioning/broken before you try to diagnose anything else.
If you need to see a visual of engine grounds, I believe shoebox has a diagram of engine grounds on his site, item number 34, 35: http://shbox.com/1/schematics_wiring.html
Scottyboy
Feb 11, 2015 10:28 PM
Injuneer
Dec 15, 2014 09:36 AM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
