Engine fires up and immediately dies
Old Dec 22, 2005 | 06:03 PM
joshp007's Avatar
Ok well I got my fuel pressure problem fixed. I have good spark and I am getting fuel but when I crank the car over it revs up and immediately dies. Any ideas? Vats?
Old Dec 22, 2005 | 08:01 PM
n2oCamaro's Avatar
Re: Engine fires up and immediately dies
Have you tried opening the throttle slighty immedialty after starting it. If it stays running with the blades cracked open then you may have an AIC issue. Is this a new combo or did it just start doing this out of blue?
Old Dec 22, 2005 | 08:06 PM
joshp007's Avatar
It started doing it out of the blue. It wont run even if they are open
Old Dec 23, 2005 | 09:20 AM
1quickTA's Avatar
could be a vacuum leak. A BIG vacuum leak. I know when I installed my headers, I had forgotten to put my EGR block off plates on and it did that. You said it started "out of the blue" so a large leak is not as likely, but something to look into. Good luck getting it fixed and running.
Old Dec 23, 2005 | 10:28 AM
got8?'s Avatar
Does it give a code? Could be some kinda air metering problem. Could be a vacuum leak.
Old Dec 23, 2005 | 10:35 AM
joshp007's Avatar
Yea I need to get it scanned I am guessing
Old Dec 23, 2005 | 09:05 PM
Joe 1320's Avatar
What does the gauge cluster do? When my ignition switch was going south, the symptoms were exactly as you described. Sometimes the car might run and then just cut off, Usually just die as soon as it fires.
Old Dec 24, 2005 | 03:03 PM
joshp007's Avatar
I just put a new ignition switch in
Old Dec 24, 2005 | 07:04 PM
PredatorZ28's Avatar
check fuese my car did that and it was a fuse in the dash panel
Old Dec 24, 2005 | 10:36 PM
joshp007's Avatar
I have been through all the fuses. Which fuse did it on your car?
Old Dec 24, 2005 | 11:17 PM
amean94ta's Avatar
mine did that twice once i ripped my intake elbow and it did it the second time i oiled my k&n too much and the oil took out the maf
Old Dec 24, 2005 | 11:23 PM
joshp007's Avatar
I have a trick flow elbow and the maf has been checked out
Old Dec 25, 2005 | 01:42 AM
luckyou03's Avatar
this is the bad karma you will receive for scamming me. Now your car wont run
Alex Barnes
Jan 24, 2015 10:21 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
Timberwolf
Aug 9, 2002 11:24 AM
