Engine dies while driving
Old Mar 30, 2018 | 03:09 PM
Aftmost's Avatar
So I’m driving just about anywhere and sometimes after a while the engine will sputter and die sometimes it starts right up some times it takes a while to start back up what are things I can check and do to resolve problem engine is a 94 our of a b body
Old Mar 30, 2018 | 08:02 PM
Re: Engine dies while driving
Check the fuel pressure, with engine under load. Scan it for codes. Have the ICM tested, making sure they get it good and hot. Then there's Scan9495 to run a PCM data log while the car is driven under conditions that produce the stall.
https://www.camaroz28.com/forums/com...95-lt1-874306/
How many miles on the engine? Has the Optispark been replaced? If so, with what brand?
03RCode
May 19, 2021 12:12 PM
ManiacRacing
14
Feb 4, 2011 09:51 AM
dirtgar
Oct 28, 2010 05:50 AM
TACamaro
May 8, 2007 07:49 PM
texasTA
May 1, 2003 02:31 AM
