Engine Compatiblility Question 95lt1-96lt4
Old Feb 27, 2004 | 06:36 PM
lookingformore's Avatar
Just got an offer to purchase a 96 LT4 Corvette motor-grand sport- I have an 95 z-28........can any one tell me what i will have to do to it to make it work.......I know i would have to upgrade the computer....but what else......it is said to have everything on the motor.....just need fuel rail...will mine work with this LT4......and the price is around 4K...should i jump on this.....
Old Feb 27, 2004 | 07:34 PM
Camaro_Maniac63's Avatar
I think the only difference other than what you already mentioned is a couple of brackets that are different for the engine bay in a Camaro.
I would build myself a 4-bolt main stroker for $4000, unless you want to be different with the LT4. Good luck.
Old Feb 27, 2004 | 07:40 PM
OBE1 95Z28's Avatar
The 95 OBDI computer can "manage" your LT4 engine if you have the ERG programmed out. The LT4 didn't need an ERG valve as the cam took care of this. You'll need to use your 95 knock sensor and you will not use the crank position sensor that comes on a 96 engine. The programming should also be changed to optimize the fuel curves/timing for the higher HP/RPM setup.
Old Feb 27, 2004 | 08:47 PM
Buttercup's Avatar
That's almost enough to build a performance engine, why waste it on a stock engine with only 330 advertised hp?
Take the money and buy heads and cam (looks like you've already got some of the supporting hardware) and make twice the power gain for half the money.
That's just what I'd do, er, did
Old Feb 28, 2004 | 07:03 PM
re-build instead of stocker
Thats what i was thinking...re-build bottom end..not stroked but upgraded...and cam and head work....and i was guessing i would be around the same price but alot better off horsepower wise......Is that the basic theory on this?....Doesn't look like any one would buy this engine for that much money...for only stock performance numbers.....
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Jan 11, 2015 03:47 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
squirrels
Jul 13, 2002 01:58 AM
