Do i have to use the stock balancer with an underdrive pulley???
Old Feb 28, 2004 | 06:15 PM
ChevyTuffD.A.'s Avatar
I had just read a post that indicates that i have to use the stock balancer with an underdrive pulley. I thought the pulley served as the balancer also. If i have to use the stock balancer too then how does this underdrive pulley fit on there?? Its the motorvation pulley from Summit Racing.
Old Feb 28, 2004 | 07:17 PM
OBE1 95Z28's Avatar
You double them up, the underdrive pulley mounts closest to the block with the stock pulley/balancer mounted in front of it. The pulley should have come with longer bolts.
Old Feb 28, 2004 | 07:25 PM
96LT14u2Nv's Avatar
as already stated. they go together
there are some underdrive pulleys that act as a balancer but the only ones that come to mind are ASP pulleys'
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
94z28jbw
Sep 8, 2002 03:22 PM
