engine break up
Old May 24, 2005 | 11:39 AM
rich152's Avatar
engine break up
ok im new and was hopeing ya'll might be able to help me.
got a 96 formula. just got the motor back from stroke to 383. before it went in it would pull to 62-6300 rpm no problem. now that the new motor is broken i have been playing around with it the engine stuters at 5200. some times it will pull through it sometime it wont go any higher and just falls of. i got a lt4 intake, heads and ecm so i know it has the lt4 KM i checked. opti is same one off the original motor with 55000 on it.
Can anyone help?
Old May 24, 2005 | 04:58 PM
taguy001's Avatar
Re: engine break up
That sounds like an opti problem, it's always a good idea to change them out when you pull the motor apart cause the water pump is right over it and tends to leak fluid on them when pulled.
Old May 24, 2005 | 05:51 PM
rich152's Avatar
Re: engine break up
i checked the spark today and everything seemed fine does the optic in the unit help send signal for advancing the timing or just for basic timing?
Old May 24, 2005 | 07:05 PM
taguy001's Avatar
Re: engine break up
can't really help you there however just because you're getting spark doesn't mean that it's bad. I would really doubt that it's a timing problem with the way you describe it, if it was timing the motor would still pull through. I take it you had the car properly tuned correct?
Old May 24, 2005 | 07:16 PM
1racerdude's Avatar
Re: engine break up
Valve spring??
Old May 24, 2005 | 07:25 PM
rich152's Avatar
Re: engine break up
the tuning has not been done yet i wanted the car to be broke in before i get it done the only programing is the hypertec crap form before the build. and the spring im not sure what is an easy way to check them.
Old May 24, 2005 | 07:27 PM
1racerdude's Avatar
Re: engine break up
Ask the person who did the heads.
Old May 24, 2005 | 07:38 PM
taguy001's Avatar
Re: engine break up
to check the springs you have to pull the valve covers. Try taking off the hypertec tuning and see what happens, those tunes usually add timing and you may be getting false knock from that. What kind of compression does the motor have?
Old May 24, 2005 | 08:15 PM
rich152's Avatar
Re: engine break up
its running almost dead on at 10.6:1 i just read another question about this same problem from another user his problem was the ignition module what do u think?
Old May 26, 2005 | 07:00 AM
rich152's Avatar
Re: engine break up
ok i tried the icm replacement to no avale. opti i think is next. i called the shop that did the heads they said they replace everything with the package i paid for. i just hate to do the opti if its not the problem, its so expensive. but unless anyone can think of anything else let me know.
Old May 26, 2005 | 11:03 AM
RE AND CHERYL's Avatar
Re: engine break up
What injectors are in it? What cam are you using?
If you are running a stroker 383 with a bigger cam and injectors on a basically stock tune, I would expect it to run like crap. Get it tunned.
Old May 26, 2005 | 09:51 PM
spcearle's Avatar
Re: engine break up
boy this prob sounds real familiar ...i'm having the same prob with my new 383......we replaced the opti in it with a autozone one which was a mistake in the first place i guess...and now pulling that and putting a unit from summit in it...we had my car out on the roads hooked to a scanmaster monitering a whole bunch of things and detirmaned it was the opti indeed or so we think so the new opti will be goin in tomorrow so lets hope thats it and lets see where you get on yours...my car just stutters and stumbles from about 5500 on up till i shift at wot
Old May 27, 2005 | 04:08 PM
rich152's Avatar
Re: engine break up
i replaced everything but the opti now going to do that next week. i hope it solves the problem.
Old Jun 3, 2005 | 12:52 PM
rich152's Avatar
Re: engine break up
ok i have now spent to much on this stuff. still got the problem. i have been reading a million post on this same lt1 problem. this is were i am tonight i am going to check for arching again. this seems to be a concensis. one way or another. i have replaced everything to no avale. so i will check this and see what i am getting. im going to do it at night so i can see better. i have seen this problem on my car before but didnt think these problems were realated but we will see.
Old Jun 3, 2005 | 03:45 PM
Feenix's Avatar
Re: engine break up
have you tested your fuel pressure??
cmyname1
Feb 19, 2015 08:38 PM
grabbem88
Feb 13, 2015 03:09 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
dmaastr
9
Jul 1, 2002 02:22 PM
