engine block differences
Old Nov 27, 2006 | 12:27 PM
94formulacoup's Avatar
Can I use a sbc block with my lt1 heads and parts and if not what are the differences? I have an electric water pump so i only need to drive the optispark.Can anyone tell me what i would need to do or if it is even possible.
thanks
Old Nov 27, 2006 | 12:31 PM
JohnnyPappis's Avatar
the lt1 has reverse flow heads so the coolent passeges are diffrent and the lt1 intake wont fit without some work either
Old Nov 27, 2006 | 06:55 PM
The water pump passages and bolt pattern are totally different than the SBC as well. IMO, trying to mix the two is an exercise in seeing how fast you can empty your wallet (to no real advantage).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
willismoons
Feb 14, 2015 08:42 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Jul 4, 2005 05:00 PM
