Engine block to chassis ground wire (shoebox?)
Old Jun 14, 2003 | 07:54 PM
x7x7's Avatar
Anyone know where the main chassis to engine block ground is? I image shoebox knows and has pictures to go along with his explaination.
Old Jun 14, 2003 | 08:38 PM
Dave88LX's Avatar
I do remember a stud w/ a bolt on the bottom of the passenger side of the engine...and when I went to unscrew the nut, the stud came out instead, and I didn't have a wrench skinny enough to hold hte stud while I turned the nut w/ a socket and ende dup having to cut the eye terminal off. I think that's the only one I noticed....
Old Jun 14, 2003 | 10:52 PM
There is a braided ground strap that goes from the LH coil stud to the LH front subframe (chassis/body) rail.
On the other side of the block, in front of the motor mount is where the negative battery cable is grounded.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Jan 5, 2015 07:14 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
kandied91z
Aug 6, 2002 01:18 AM
