Engine Balencing Mechanical Problem
Old Jun 28, 2006 | 01:27 PM
Z28 97's Avatar
I brought my car up to the dealship and he said i have a Engine Balnecing Mechanical Problem...He said it might be the flywheel...hes saying i need to remove the tranny, remove clutch assembly, and start it to see if the flywheel is messed up or suttin...ne reccomendations...how much u think this will cost? si ti worth it
Old Jun 28, 2006 | 01:30 PM
NVetro's Avatar
Re: Engine Balencing Mechanical Problem
huh?!?! lol. Lets start from step 1, what is exactly wrong with the car, what are you expirencing?
Old Jun 28, 2006 | 01:37 PM
Z28 97's Avatar
im not good at explainin what is wrong...but he said its got a vibration at lik 2000 rpms...
Old Jun 28, 2006 | 02:30 PM
NVetro's Avatar
I think he is pulling your chain, if it was an engine ballancing problem (and your motor is stock i assume) wouldn't that "vibration" happen at all rpms and not just 2000rpms, hahahhaa. He is definitly pulling your chain, look into your spark/ignition system, sometimes a slight misfire can cause your car to shake at 2k. If it was something MAJOR like an engine balancing issue it would vibrate you out of the car and you would feel it all the time.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Jazsun
Dec 29, 2014 12:14 PM
mspennyhughes
Nov 28, 2014 03:22 PM
