Engine balancing info...some PRE-questions!!
Old Mar 21, 2003 | 08:37 PM
DubbyZ28Camaro's Avatar
Okay, just would like to know what the hell is going on before I even start buying parts for a 383. What balancing options do I have?? I will be buying my own pistons, rods, crank rather than in a kit, so what type of shop do I take it to get balanced??? Would internal balancing be the best then for a 383??
What do the crank hub, balancer, and flywheel all need to be balanced at then??? Would they be neutrally balanced if everything is internally balanced???
Sorry for all of the questions, but balancing is the most confusing thing to me right now before I begin spending gobs of money on a motor.
Old Mar 22, 2003 | 07:18 PM
badass383's Avatar
Well I did a 383 like you are doing and what a pain in the *** it was. Most cranks are not set up for internal balance. As you know all one piece rear main seal cranks are externally balanced. To internally balance means adding mallory which can get expensive.
When you go internal, the accessories have to be neutral. The balancer is no problem but the flex plate can not be found with neutral balance so you have to pay to balance that too.
The Callies Dragon Slayor crank seems to be the most cost effective crank to get. It seems to need little or no metal added and usually metal removed which is what you want to balance to save money.
Based on the pain I went through, you will be much better off getting a balanced kit. There are very good ones available through a variety of companies.
Long live the 383. Keep marching on buddy. You'll get there.
Good luck
Old Mar 23, 2003 | 01:31 AM
Yeah, right now I just have the block I'm waiting to hand out some money for (which I haven't actually confirmed a buy yet)...and an LT4 intake manifold in which I am purchasing in the next few weeks. I'm just in the beginning stages, and this was probably the most confusing part of it all to me.
That info is very helpful and it sounds like the balancing part is just a total PITA from a few experiences that I have heard.
Old Mar 23, 2003 | 05:55 AM
badass383's Avatar
Doen't the LT4 intake limit your choice of heads? Is there something special about that intake?
Just curious.
Old Mar 23, 2003 | 10:21 AM
Yep...gotta have LT4 heads...but thats what I want!! I was looking at the AFR LT4 195cc's with competition street porting and the hydra-rev kit.
The heads are where my money is going to be really spent on this motor.
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:33 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
Nostang 96z
Sep 15, 2002 10:15 PM
