Engine balance?
Old Sep 25, 2006 | 10:28 AM
doo_man's Avatar
Engine balance?
Swapping out original LT-1 6 spd) from my Z-28 for a Corvette LT-1 (auto), I am going to replace the flex plate with my flywheel but should I have balance concerns? Also, should the dampers be changed or can I use vette damper with my flywheel or is the balance going to be affected?
Old Sep 25, 2006 | 03:18 PM
The Engineer's Avatar
Re: Engine balance?
The rear of a “stock” LT1 is "externally" balanced, therefore, you'll need to use a flywheel, or flexplate with the external counter-balance weight. Also, the roll-pin key on the crank ensures proper clocking of the external weight.
The front of all stock LT1s are "internally" balanced and they use a harmonic damper, not a harmonic balancer.
Most rebuilt LTs (especially strokers) are changed to "rear internally balanced," which then requires changing the rear flywheel, or flexplate to the type without a counter balance weight.
WD
Old Sep 25, 2006 | 05:08 PM
JustNO's Avatar
Re: Engine balance?
WD
Neutrally Balanced
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:33 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
Nostang 96z
Sep 15, 2002 10:15 PM
