Engine almost in!!! PICS INSIDE
Well i should be able to finish my motor by tomorrow. Just gotta put my clutch in and bolt up the tranny then drop the car back on it. Here are some pics of my progress. Once its in just gotta wait till i get my PCM back. I'll keep you guys posted
Here is the old motor getting dropped from the car
Here you can see the engine on the hoist, the tranny sitting down and the cradle right behind it. I took them apart so i could pressure wash all the stuff and paint some things.
Here is the new motor going in, 383 with some goodies
yeah im a "lube tech" at a chevy & cadillac dealership just trying to work my way up. I got a master tech helping me with the swap and all he wants in return is the old motor!
Thanks i need all the luck i can get. I already came across a couple problems, but always get to work them out
Nice Z28
Wow, that shop that you are in right now, looks very similar to where I work at, even the same Rotory lift, I am a junior tech at the moment, but the wiered think is, I have a White Camaro Z28 like yours , not sure what year you have, but I have been "planning" to put a stroker on mine. May be this a sign to do it. Mine is completely stoke.
made some more progress today, here are a few more pics:
Added the new clutch and flywheel
Most of the stuff transfered over to the new motor
Pretty much got the whole powertrain all in tact. Now it was time to lower the car....
Got everything sitting in and bolted down. Its a little messy, still gotta clean up the engine bay
Well so far today everything is together and the car is rolling. Im just waiting for a few things to get tomorrow at work. I gotta put a new knock sensor on, new belt because i ditch the underdrive pulley. Put on my fuel rail and install the PCM once it get back from Ion....i'll keep you posted on the progress.
Here are some specs if you guys are curious:
383 Eagle Forged rotating assembly
Comp XFI 468 w/ 1.6RR
Stage 3 CNC ported/polished heads
Ported intake with 58mm TB (TB bypass)
CAI, Granatelli MAF
SVO 42lb. injectors
Meziere EWP
Pacesetter LT with 3" ORY
PCM tune by Madz28
!AIR,!EGR,!CATS
M6,4:10 gears, short shifter
Spec stage 3 clutch
Fidanza lightweight flywheel
Thats all i can think about for now, i might be forgetting a few stuff. Hope this will be able to put down 400RWHP
CAI, Granatelli MAF
SVO 42lb. injectors
Meziere EWP
PCM tune by Madz28
!AIR,!EGR,!CATS
Spec stage 3 clutch
Last edited by tnmotown; May 6, 2007 at 05:28 PM. Reason: added more to parts list
the heads were ported/polished by lonniesperformance.com. Awesome job on heads and have 918 springs. They flow 286/194 and think should work well with the cam.
the clutch was the stage 3 from spec. got it off ebay for around $470
maybe in a couple weeks once the motor is all broken in, i should be able to get it tuned. After that, then a few suspension mods and off to the track it goes.
Do you guys have any guess of what it might put out at the dyno/track?
12.0 range and whatever it dyno's, it dyno's - who cares? If you can get it running well and you're willing to put in the seat time, there's no reason (with a nice set of tires) that the car couldn't run deep into the 11's.
