Engine
Old Feb 2, 2009 | 05:59 PM
revolution79z28's Avatar
Engine
What are the differences between an LT1 and pre-1987 block? Is the Opti the only difference? Are the internals the same? Heads the same? I'm getting ready to rebuild my LT1 for my '93 Camaro and I want to get some ideas. I'm not new to the site but I haven't been on in awhile. Any info that ya'll provide will be greatly appreciated.
Old Feb 2, 2009 | 06:01 PM
ShownomercyZ28's Avatar
Reverse cooled head is a big one.
Old Feb 2, 2009 | 06:16 PM
ulakovic22's Avatar
Timing cover is different, roller versus non-roller, water pump (reverse cooled) like mentioned above. I think the accessory holes are still the same though.
Old Feb 2, 2009 | 06:31 PM
But are the crankshafts the same or similar? Can the Cams interchange, lifters? I'm not worried about the heads or the water pump, thats an easy fix. Could the Opti Bolt up to a pre-1987 block?
Old Feb 2, 2009 | 07:20 PM
mr_camaro96z28's Avatar
i know the cooling jackets are in different places on the heads as well as the reverse flow but not real sure on the crank and cam.
Old Feb 2, 2009 | 11:31 PM
The entire front of the block is cast different on the LT1. Its set up for a gear driven (off the cam sprocket) water pump with the inlet and outlets set up for reverse flow. And there is a mount for the Opti cast into the block. The timing cover is "different" only in shape, and has one less bolt in it, but the remaining bolts are in the same pattern as a Gen 1 SBC. As noted, the internal coolant passages in the block are different, and there is no coolant flow through the intake manifold. The thermostat mount is not on the manifold like a Gen 1 SBC. Its on the water pump housing.
You can not bolt an Opti directly to a Gen 1 block.
Cam is similar, but the front of the LT1 cam has a "step" in it for the cam retainer plate. The dowel pin is a specific length, based on whether you have the unvented Opti (92-94 short pin) or the vented Opti (95-97 long pin to drive the Opti). Crankshaft is the same as a 1-piece rear main seal Gen 1 SBC, but the balancing is different on stock cranks. Gen 1 SBC is balanced for heavier stock pistons, and for a front balancer. The LT1 is balanced for the lighter hypereutectic pistons, and does not require a front balncer. All the balance weight is added to the flywheel (or flex plate). Aftermarket cranks may be different.
Old Feb 3, 2009 | 11:40 AM
camarobird92's Avatar
Pre '87 cranks use a 2-piece rear main seal. '87 & up and LT1's use a 1-piece rear main seal.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
