Emissions- What's left to replace/check
Old Mar 21, 2007 | 06:14 PM
blaze309's Avatar
Ok i'm still failing emissions. Here's a list of the parts i've replaced, catalytic converter, optispark, plugs and wires, both 02 sensors, and i changed my oil right before i ran my car through and I got a Hc of 471 and the limit is 220. Everything else passes so what should i replace to get the hydrocarbon's down? I'm throwing 0 codes and i've tried running alcohol through and that got my Hc's down to 366 but that's still not low enough. Engine has approximatly 8,000 miles on it and it is tuned for the cam.
Also I let the tempature of my car get up to the middle mark (205?) to help pass but that didn't seem to lower it.
Old Mar 21, 2007 | 07:16 PM
respectirocz's Avatar
whats ur CO and NOx
Old Mar 21, 2007 | 07:26 PM
blaze309's Avatar
My Co is 0.80 the limit is 1.20 so that passed.
And i guess NOX isnt' tested in my area.
Old Mar 21, 2007 | 07:38 PM
blaze309's Avatar
I have a datalog file in Excel but i'm not sure who i can host it with so everyone can view it?
Old Mar 21, 2007 | 07:40 PM
LiENUS's Avatar
email it to me jacob.alberty at gmail dot come and il'l host it for ya
Old Mar 21, 2007 | 07:42 PM
blaze309's Avatar
Alright i sent it to your e-mail.
Thanks for hosting it
Old Mar 21, 2007 | 07:54 PM
96flame's Avatar
What type of test is performed? 2 speed idle, on the dyno & idle? Its obviously running rich with hc that high. Likely more tuning needed.
Old Mar 21, 2007 | 08:10 PM
LiENUS's Avatar
http://www.breakherthewang.com/camaroz28.22.csv
Old Mar 21, 2007 | 08:12 PM
blaze309's Avatar
I just started it up and let it idle and then drove it around the neighborhood a little.
Old Mar 21, 2007 | 09:15 PM
96flame's Avatar
Old Mar 21, 2007 | 09:26 PM
blaze309's Avatar
Well i figured since the test is at idle then shouldnt i data log it idle? Since somethings obviously off there>?
Old Mar 21, 2007 | 11:28 PM
ELLOKOTE5's Avatar
there are things you need to check, like is your Air filter dirty? too little o2 wont allow Check your fuel pressure, make sure that it is within specs. if it is too high it can be holding the injectors open. Also hook up a scan tool, and check the actual Engine coolant temp, if it goes bad it can make you run rich as well.
Old Mar 21, 2007 | 11:30 PM
OBE1 95Z28's Avatar
Does the car run well? I would look for others sources of fuel leaks that would cause hi HC levels; pull the vacuum line off the fuel pressure regulator and make sure it's dry as regulator diaphrams have been know to rip and allow fuel to get sucked into the vacuum line. Also might want to pull the fuel rail and check for leaking injector(s). Is your nitrous kit a wet kit? If so is the fuel soleniod leaking?
Old Mar 22, 2007 | 12:14 AM
blaze309's Avatar
The car runs a lot better then it did since i've replaced a lot of things.
I've checked the vaccum line from the FPR and i could smell gas but it wasent wet or damp inside.
I havent checked the injectors yet so that's something i need to do.
I guess I could also spend some money on a new air filter since mine is starting to get a little dirty but I didn't think it would throw my HC's off that much. Also I just replaced the engine coolant sensor (forgot to mention) so it should be working properly.
Also the nitrous isn't even on my car i'm just now getting around to installing everything. Figured i might as well since I can't drive it till i can get tags anyways.
Old Mar 22, 2007 | 08:31 AM
i dont think he's running rich because his CO levels are normal
are you burning oil?
