Emissions failed! HELP
Old Jan 6, 2007 | 02:45 PM
RKPsk8er's Avatar
title says it all. here are the results:
25/25 Test
HC read 105 ppm. limit 114 PASS
CO read .98%. limit .63 FAIL
NO read 666 ppm. limit 796 PASS
RPM 2102. 1250-2500 PASS
CO + CO2 read 14.3. 6 minimum PASS
50/15 Test
HC read 133ppm. limit 117 FAIL
CO read 1.35%. limit .65 FAIL
NO read 879ppm. limit 879 FAIL
RPM 1938. 1250-2500 PASS
CO + CO2 read 14.4. 6 minimum PASS
What should I do first? I want to fix this with least amount of money.
My car is near stock with a CAI and flowmasters
Old Jan 6, 2007 | 07:15 PM
fbodyfreak's Avatar
Isopropyl Alchohol will help. Can be purchased at almost any auto parts store. Known as HEET comes in a red bottle. Use about two of them to a full tank of gas and you should go right through, also make sure you have a clean air filter.
Old Jan 6, 2007 | 08:51 PM
RKPsk8er's Avatar
I'll try it. do I put it in and run the whole tank out then refill and retest or do I test right after I put it in?
Old Jan 6, 2007 | 10:17 PM
OBE1 95Z28's Avatar
You want denatured alcohol, not isopropyl alcohol. Isopropyl is dry gas, used for absorbing water. I suggust using 5 gallons of gas and 1 gallon of denatured alcohol.
Old Jan 7, 2007 | 11:43 AM
RKPsk8er's Avatar
how do I get denatured alcohol and how do I use it? mix one gallon with 5 gallons of gas then retest right after or do I need to run that whole tank through, refill and retest?
My dad and I are going to change the oil, clean the air filter and change plugs. Am I failing the test by enough to need to change my EGR valve and O2's?
Old Jan 7, 2007 | 12:32 PM
OBE1 95Z28's Avatar
Lowes and Home Depot sell denatured alcohol. You can test right after putting it in your tank. It's not a cleaning agent that needs to be run through the engine; it's fuel that doesn't generate any HC emissions.
Old Jan 7, 2007 | 01:06 PM
RKPsk8er's Avatar
okay will it help with my CO and NO as well? because i failed them too
Old Jan 7, 2007 | 02:39 PM
Kain's Avatar
If your car is near stock, my first move would be to replace the cat. If it hasn't been touched, it's probably bad by now.
Old Jan 7, 2007 | 03:33 PM
RKPsk8er's Avatar
what kind of cat would your recommend and how do you test to see if its bad or not?
Old Jan 7, 2007 | 07:13 PM
RKPsk8er's Avatar
I realllly need help with this because it has to pass by january 11
Old Jan 7, 2007 | 08:45 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
i am using the magnaflow / car sound cat. it was only 70 for a high flow cat when i bought it online. i just tested in ohio with the pcmforless tune and it passed with plenty of room to spare.
david
Old Jan 9, 2007 | 10:49 PM
RKPsk8er's Avatar
Bad news. I retested and failed again. Before retesting, I changed my sparkplugs, oil, cleaned the air filter, ran 93 octane BP gas with octane booster and a gallon of denatured alcohol. Here are the new results:
25/25 TEST
HC read 101 limit 114 PASS
CO read 1.00 limit .63 FAIL
NO read 506 limit 796 PASS
RPM 2115 1250-2500 PASS
50/15 TEST
HC read 1.42 limit 117 FAIL
CO read 1.48 limit .65 FAIL
NO read 737 limit 879 PASS
RPM 1927 1250-2500 PASS
I think I might change my cat next but first I need to pick one. I want one that will be good for my emmissions but also make my car sound louder when paired with my flowmaster catback. Any advice will help. thanks
Old Jan 10, 2007 | 12:41 PM
RKPsk8er's Avatar
are magniflow cats decent?
Old Jan 10, 2007 | 02:08 PM
2000GTP's Avatar
Yes, I would say they are some of the better cats on the market and you can't beat the price of them either.
Old Jan 10, 2007 | 02:29 PM
RKPsk8er's Avatar
should I be looking for something like these oval cats?
http://www.jegs.com/webapp/wcs/store...50982_-1_10251
