Eliminating EGR and AIR
Old Mar 10, 2004 | 08:03 PM
AdamZ1LE28's Avatar
If I install TPIS Long Tube Headers, I will have to eliminate the EGR valve system and the AIR injection system. What do I need to do this? Do I need a tune? Just looking for some simple instructions
Old Mar 10, 2004 | 09:28 PM
Lt1dtpower's Avatar
I just did the same thing 2 weeks ago. I sent my computer to pcmforless and I don't have any problems. Just block off the back of the intake and get you computer programed and you all set. You can make your own block off plates its easy.
Old Mar 11, 2004 | 10:02 AM
AdamZ1LE28's Avatar
And just remove the AIR pump and all its hoses? Or do I need programming for that too?
Old Mar 11, 2004 | 10:32 AM
TraceZ's Avatar
1996 was OBD2. You'll need reprogramming to remove the airpump.
in OBD1 cars you can remove it as long as you leave the fuse in place.
Old Mar 11, 2004 | 01:57 PM
Bersaglieri's Avatar
So with the OBD I, I can lose the AIR without programming, what about EGR? Need programming then?
-Dustin-
Old Mar 11, 2004 | 02:09 PM
importeater's Avatar
Some good reading about this topic.. http://web.camaross.com/forums/showt...m&pagenumber=1
Old Mar 11, 2004 | 02:26 PM
Thanks man, good info
-Dustin-
Old Mar 11, 2004 | 03:03 PM
slider's Avatar
Does anything else need to be removed in order to get to the AIr stuff to remove it or can you easily get the ratchet etc in there?
Old Mar 11, 2004 | 04:02 PM
slider's Avatar
Old Mar 11, 2004 | 06:37 PM
Spinner's Avatar
AIR is easy enough. Nothing else necessary
HectorM52
Jul 30, 2017 11:46 AM
k1996z28
Jan 21, 2015 07:22 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
