Eliminate FMU?
Old May 26, 2003 | 04:08 PM
DAC350's Avatar
Eliminate FMU?
With my mods and having LT1_edit, is there a safe way to eliminate the FMU?
Old May 26, 2003 | 04:30 PM
94SLUG's Avatar
Many ways, I dont use a FMU never have never will. Run large injectors and a big fuel pump. Im using 42lbs and gss340 intank with a MSD Boost A Pump. Overkill yes, I like fuel on any FI motor. This should support 15psi and im at 12psi 5800rpms.
Old May 26, 2003 | 06:34 PM
GEES97TA's Avatar
Hey DAC350, how does your car run.Did you ever have it dyoned to see what you are putting down?
I have no FMU either my was elimated and they put in 37 lb injectors and did a wide band dyno tune....so far so good
How does your car sound with your exhaust set-up i have MAC's also with a magnaflow exhaust is stinks i hate the raspy sound i have
Old May 26, 2003 | 07:07 PM
DAC350's Avatar
Sounds mean as hell. Almost as loud as when I just was running off the manifold. Does smell though since !cat. 3rd gear going 70 mph, no one tries anything. No dyno, but I run 12.9 in the 1/4. Traction issues still, and I need more practice at the tree.
Old May 26, 2003 | 10:27 PM
GEES97TA's Avatar
cool, you should be able to run mid 12's when you get the lights and better traction, i didnt run my car yet im hoping for mid 12's ..
I have to get a different muffler because mine has a bad raspy sound above 3000 rpm i cant stand it..
Old May 26, 2003 | 11:15 PM
ATMINF's Avatar
I took off my FMU because the car started to run very choppy. Found out later that the diafram(SP) went bad. I would say with a good tune run without a FMU and you should be good. Its one less part that can fail.
Victor Lamb
Aug 26, 2017 02:52 PM
MDZ28
Sep 7, 2015 09:16 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Aug 7, 2015 08:52 AM
Jul 10, 2015 02:23 PM
