Electronic vs. Thermal Flasher?
A thermal flasher has a bi-metal strip in it that heats and cools. The rate at which it does this is dependant on the make-up of the strip, itself and the amount of resistance in the lamp circuits. This results in the "flashing". Ever notice someone pulling a trailer, that the turn signals flashed very fast? That is because the normal flasher on the vehicle was not rated for the additional load of the trailer lighting. More resistance=more rapid heating of the flasher=faster flashing. That is why they sell heavy duty flashers for towing.
An electronic flasher is not dependent on a bi-metal strip and will perform the same no matter what the load (at least that is the way I understand it
Sorry if that is more than you wanted to know.
).Sorry if that is more than you wanted to know.
That was the perfect amount of information. Thank you for the clearification on the matter!!!
I have read many of your post on the matter of the blinker and I have taken heed. I am going to try a couple of things and see if I can get my blinkers to work properly again.
Henson071
Aug 4, 2015 09:32 AM
