Electronic vs. Thermal Flasher?
Old May 22, 2003 | 08:55 AM
DPassion's Avatar
Question Electronic vs. Thermal Flasher?
May be a silly question, but what is the difference between an electronic and a thermal turn signal flasher? Pro's and Con's? Thanks!
Old May 22, 2003 | 09:27 AM
A thermal flasher has a bi-metal strip in it that heats and cools. The rate at which it does this is dependant on the make-up of the strip, itself and the amount of resistance in the lamp circuits. This results in the "flashing". Ever notice someone pulling a trailer, that the turn signals flashed very fast? That is because the normal flasher on the vehicle was not rated for the additional load of the trailer lighting. More resistance=more rapid heating of the flasher=faster flashing. That is why they sell heavy duty flashers for towing.
An electronic flasher is not dependent on a bi-metal strip and will perform the same no matter what the load (at least that is the way I understand it ).
Sorry if that is more than you wanted to know.
Old May 22, 2003 | 09:44 AM
DPassion's Avatar
Cool
That was the perfect amount of information. Thank you for the clearification on the matter!!!
I have read many of your post on the matter of the blinker and I have taken heed. I am going to try a couple of things and see if I can get my blinkers to work properly again.
Old May 22, 2003 | 11:07 AM
DPassion's Avatar
Talking
Just purchases a Flasher from Wal-Mart for $1.98+tax. Now, everything seems to be working properly!!! Thanks again everyone!!!
drt
Sep 27, 2015 04:39 PM
Henson071
Sep 18, 2015 04:01 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Henson071
Aug 4, 2015 09:32 AM
