Electrical taping a ground wire...
Old May 20, 2005 | 04:15 PM
Hawk350's Avatar
Is this a good Idea or not? I have a wire that seems to be the problem of all my issues. It is long, steel braided. I am thinking about taping it with electrical tape so if it makes contact with a metal surface, it wont affect anything.
Old May 20, 2005 | 04:17 PM
captskin's Avatar
Re: Electrical taping a ground wire...
I would think so, just wrap it up in electrical tape real good..
Old May 20, 2005 | 04:22 PM
Hawk350's Avatar
I thought so too, just making sure....
Old May 20, 2005 | 04:34 PM
If its a ground wire, why would there be a problem if it touched a "metal surface"? All the metal surfaces should already be grounded, and at the same potential as the ground wire.
Old May 20, 2005 | 04:42 PM
Hawk350's Avatar
The ground wire is long, it can potentially try grounding to another point if I run over a bump and it sways....there is much play in the wire...
Old May 20, 2005 | 05:03 PM
Dave89IROC's Avatar
and, what is the problem?
Old May 20, 2005 | 05:40 PM
Hawk350's Avatar
my car threw all kinds of codes....lean, est grnd, misfired, and when I adjusted this wired, it was fine. Last night took the car out and ran great wth the wire tucked away. Grounds=problems when not grounded correctly.
Old May 20, 2005 | 05:50 PM
Dave89IROC's Avatar
that is not from it touching, it is from corrosion at the ends, I would remove it and clean the ends
Old May 20, 2005 | 05:52 PM
Hawk350's Avatar
which ends, plugs? The has silicone on them....what corrosion are you referring to?
Old May 20, 2005 | 10:20 PM
OBE1 95Z28's Avatar
What is this wire connected to?
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
