Electrical Question
Old Nov 12, 2011 | 05:32 PM
  #16
JackBlack95's Avatar
Re: Electrical Question
Originally Posted by speedygonzales
So ohm the wires from the ECT connector to the PCM connector.
If I did it right, I got nothing. Guess the next step would be to run a jumper and check?
The Black wire had resistance but the yellow wire didn't.
Old Nov 13, 2011 | 06:48 AM
  #17
Guest47904's Avatar
Guest
Am I missing something here ?
Going back to your original post.
I'm getting +5v to the new ECS. Is this telling me the wiring between the PCM and ECS are good?
When you measured the 5 volts at the ECT connector, did you put one lead of the meter on the yellow wire contact and the other lead on the black wire contact? Or did you use an engine ground instead of the black wire?
One other point. If during all this time, the ECT circuit was a problem you would have a SES light. So my questions are: Does your SES light work during prestart diagnostics? And the other is, when you put your jumper(paper clip) in the connector, did you start the engine?
Have you tried simply disconnecting the ECT with no jumper and starting the engine to see if the SES comes on?
If that is what you are saying, then did you confirm the actual temperature of the coolant reaches 227 degrees and the fan is still not on? or did you always shut it down before you MAY have actually reached that temperature?
I shut it off when it got real close to the RED and when I shut it off I can hear a lot boiling and all the hoses are real hot.
Based on your posts I think you're chasing ghosts. Your whole entire problem could be explained by a bad radiator cap.
Old Nov 13, 2011 | 10:34 AM
  #18
Re: Am I missing something here ?
When you measured the 5 volts at the ECT connector, did you put one lead of the meter on the yellow wire contact and the other lead on the black wire contact? Or did you use an engine ground instead of the black wire? I put one to the yellow and one to the black.
One other point. If during all this time, the ECT circuit was a problem you would have a SES light. So my questions are: Does your SES light work during prestart diagnostics? Prestart Yes goes out when the engine is started And the other is, when you put your jumper(paper clip) in the connector, did you start the engine? No just turned the key to the on position
Have you tried simply disconnecting the ECT with no jumper and starting the engine to see if the SES comes on? No , I'll do that next. Getting ready to head back out there.
I changed the radiator cap earlier (Still could be bad I recon.....)
Old Nov 13, 2011 | 01:13 PM
  #19
Unhooked the ECT and started the car. The SES light came on and the fans came on.
Old Nov 14, 2011 | 05:23 AM
  #20
Guest47904's Avatar
Guest
Ok so you know the circuitry is good. Now either test or replace the ECT. Personally I would test the ECT in boiling water. You could also place a resistor in the wiring to push the fans on.
Old Nov 14, 2011 | 08:36 AM
  #21
Cool, Here we go. Think while i'm in town I'll stop at the GM dealer and get a thermostat, ECT and radiator.
Old Nov 14, 2011 | 01:44 PM
  #22
Allright. I put in the new ECT and ran the car at idle. It got to 3/4 up on the temp gauge and no fan kicked on. I got in the car and reved it up then the fans kicked on. I turned the car off let it sit 15 minutes then started it back up let it run and the fans kicked on by themselves. They were kicking on at 3/4 and turning off at 1/2. Seems a bit high but I guess the only way to verify the temp is to purchase a scanner or laptop cable. I have to go to work so I won't be able to run the car up the road but fingers are crossed.
For those of you keeping score at home I just bought a new ECT at O'reilly and it looks like that was the problem.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Moshbmx1
Feb 17, 2015 10:51 AM
guyomatic
Sep 11, 2002 02:11 AM
