Electrical problems prior to startup...
Old Nov 13, 2003 | 08:08 PM
fredmr39's Avatar
Lightbulb Electrical problems prior to startup...
Never before have I had this problem: Today, my car started as normal in the morning, I turned the key into the "on" position, waited 2 secs, then started the car (why do i wait 2 secs? habit i haven't broken out of since I installed my new fuel pump) anyways, after letting the car sit then for 4 hours, i turn the key into the "on" position, the lights blink briefly, i hear the seatbelt ding very quickly, then it resumes as normal and all lights up, then starts fine....however, after starting its as if my battery had been disconnected (ie: stereo reset, trip odometer reset to 0, etc) This happened again 2 hours later, and the 3rd time after 3 hours it only reset the trip odometer, and not the stereo....? Any ideas?
once again, heres what happens:
- turn key to on position
- Dash lights flash on, then quickly off, then on again
- car acts as if battery was just reconnected
Thanks for any info.
Old Nov 13, 2003 | 10:23 PM
Check your battery cables and the connections on the RH shock tower.
Old Nov 13, 2003 | 11:50 PM
fredmr39's Avatar
shoebox - thanks a lot for your input, ill be sure to check that out again in the morning...i looked things over once briefly, but things are usually diff 2nd time around thanks again
Old Nov 14, 2003 | 08:15 PM
fredmr39's Avatar
nothing appeared to be loose.....however I disconnected and reconnected all of my connections and the problem seems to be gone....... >: -> .........thanks shoebox
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
97z28k&N
Jan 9, 2015 04:58 AM
Collector Car
Jan 5, 2015 10:58 AM
