Electrical Problem, 97 Z28, ABS & Fans offline...
Old Oct 25, 2014 | 11:18 PM
MGroff's Avatar
This is driving me in circles, ABS Inop light comes on, Traction Control turns off, and fans do not operate. In the beginning this would happen for about 5 min, then everything would come back and be normal for days/weeks. Now everything is off and not coming back on. Seems to be all linked. Checked every ground could think of, and all the relays/fuses. Pull the temp sensor, fans turn on. Anyone else ever have this problem or know a solution?
Old Oct 26, 2014 | 11:05 PM
GaryDoug's Avatar
Prominent Member
Re: Electrical Problem, 97 Z28, ABS & Fans offline...
Those items and the horns are all fed from fusible link K. That is one of the gray "2.0 SQ MM" ones in the bundle atop the shock tower near the battery. Try turning on the ac to force the fans on, and wiggle all of them one-at-a-time till you find one that is intermittent for the fans.
http://shbox.com/1/fusible.jpg
squarehead
Jan 15, 2015 07:02 PM
97z28k&N
Jan 9, 2015 04:58 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
4586
Dec 31, 2014 02:21 PM
Jul 4, 2005 05:00 PM
