Electrical connectors on M6, which one is which?
Old Mar 14, 2003 | 04:48 PM
JDMZ28's Avatar
There is one on the passenger side and three on the drivers side, which one is which?
Old Mar 14, 2003 | 05:46 PM
JDMZ28's Avatar
ttt, sorry gotta know.
Old Mar 14, 2003 | 05:49 PM
Dave 96TA's Avatar
I believe 2 on the driver side are the CAGS solenoid (rear) and reverse-lockout solenoid (further forward). Someone correct me if I'm wrong. Those two I know for sure have the same connectors since I accidently !CAGS my reverse instead of my CAGS 'noid . The CAGS solenoid will be directly next to the shifter base if I remember correctly.
The pass side may be for the E-brake or the Neutral safety switch.
Old Mar 14, 2003 | 06:22 PM
JDMZ28's Avatar
I think the one on the passenger side is the VSS. Whats the one that controls that stopper that stops the shifter from moving? Its gotta be the reverse lockout or the CAGS for sure.
Old Mar 14, 2003 | 06:29 PM
Dave 96TA's Avatar
CAGS locks you out of 2nd and 3rd under certain conditions, and Reverse Lockout locks you out of reverse when you're above a certain speed, etc. Search the web for CAGS solenoid and you're sure to find some pics.
Old Mar 15, 2003 | 05:28 PM
JDMZ28's Avatar
I think the one by the input for the shifter is for CAGS, the one under that is probably the reverse light switch, and the one on the front is probably the reverse lockout. COME ON GUYS SOMEBODY HAS TO KNOW..........
Old Mar 15, 2003 | 07:05 PM
gb95zconv's Avatar
passenger side is for the backup light.
drverside....closest to shifter is the rev lockout
under it is the vss
the last one near the middle is the skip shift
Old Mar 15, 2003 | 11:41 PM
Driver's Side
Old Mar 15, 2003 | 11:54 PM
smokindastangs's Avatar
sorry for the idiot question...but what does m6 refer to?
Old Mar 15, 2003 | 11:57 PM
M6 = 6-speed Manual transmission (Borg-Warner T56). As opposed to the A4 = 4-speed Automatic transmission.
Old Mar 15, 2003 | 11:59 PM
ahhh...see i knew it had to be simple...i just couldn't figure it out.
Old Mar 17, 2003 | 03:44 PM
JDMZ28's Avatar
Thanks guys.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
