Electrical in 93 LT1
Old Nov 9, 2005 | 11:06 AM
sprawl333's Avatar
I have a 93 Z-28 that I puchaced this summer as a fixer upper. Well my most annoying and unexplained problems are as follows....Turn signal indicater lights stay on with the headlights. I have checked all the grounds I have found and it fixes nothing....temp gage does not work but temp sensor does. Power dooer locks dont work on eighther side( no click, power to the switch and continuity in the switch) Windshield wipers spass out and stop in the up position from time to time. Thats bout it for now......Any Ideas
Old Nov 9, 2005 | 12:07 PM
FuryZ28's Avatar
Re: Electrical in 93 LT1
don't know about the others, but with the turn signal, I had that problem for years, come to find out that I had the wrong bulb in there. 93's use a year-specific bulb- #2397 I believe. You can check that number at the local parts store. I changed the bulb and that solved my problem...
Old Nov 9, 2005 | 02:18 PM
sprawl333's Avatar
I was wondering....is that the bulb in the dash or in the front or rear of the car?
Old Nov 9, 2005 | 06:14 PM
FuryZ28's Avatar
That's the main bulb in the front. Mine did the same thing, it would just "light up", but wouldn't flash/blink. It was weird. Anyways, once I put the right bulb, both the turn signal and dash were flashing like they should...
RUENUF
May 25, 2016 08:10 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
