Electric Waterpump Worth It?
Old Mar 31, 2004 | 01:09 PM
c0rey's Avatar
Hey I was wondering if a electric water pump would be worth the money. What Gains Can I Expect. And Should I do it since this is my DD pretty much?
Old Mar 31, 2004 | 03:04 PM
VegasZ's Avatar
You will lose the high rpm drag of the stock water pump. And the electric will cool better at idle. The drawback is, you have to keep more of an eye on it because when it goes out, you can overheat quickly. You can install a warning light for when it goes out. I have the Meziere and like it.
Old Mar 31, 2004 | 03:09 PM
ZDriver96's Avatar
CSI here.. I like it... It has every advantage over a mechanical except when it goes it just goes... no leaking out a weep hole for a warning.. But everything else is better, cooling, bleeding the system, changing it again, around 7rwhp on a stock or near stock engine.
Old Mar 31, 2004 | 03:14 PM
Grease's Avatar
http://www.ws6.com/mod-14.htm
As you can see from that they do help free up some HP plus they flow more coolant than the stock pump. Since I never pay attention to my guages, my pump is wired in series with my MSD ignition. So hopefully if my pump fails my car won't run. I don't know if it will work but I hope I'll never have to find out.
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
blaze309
Sep 8, 2015 05:27 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
