electric waterpump relay hookup
Old Aug 1, 2007 | 06:52 PM
chas010's Avatar
Hi guys i just got done installing a mezeire electric waterpump on my 1995 z28, as far as a hot source for the relay what do you guys think of the fog lights (there long gone) fuse in the junction box under the hood? i dont want to run the wire all the way back under the dash.
Old Aug 1, 2007 | 07:19 PM
wicked_95z's Avatar
I have my source coming from the junc box on the pass fender and mounted the relay on the firewall( !a/c) Make sure you put a fuse in line as well. My first pump I didnt have fused. The water pump motor shorted out and damn near burned the car down
Old Aug 1, 2007 | 07:42 PM
chas010's Avatar
hey, thanks for the heads up, ill def have a inline fuse from the relay to the pump.
jason
Old Aug 1, 2007 | 07:44 PM
er-z's Avatar
i just use abs fuse for my turn on lead for relay .it hot when key is in the run position but not when turned backwards . hope this helps you .
erick
Aaront810
Aug 29, 2020 09:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
