Electric Waterpump installation notes
Old Nov 29, 2003 | 11:16 PM
Heatmaker's Avatar
Advanced Member
I plan to do the install sometime after I'm done spraying the car.
I was wondering after I drain the coolant...can I just dump it back in at the Fill cap area? Or do I need one of those machines to pump the coolant back through the system?
Old Nov 29, 2003 | 11:30 PM
94formulabz's Avatar
386-776-1476
http://www.csiperformance.com/pdf/901LT1.pdf
800-208-1755
http://meziere.com/
Old Nov 30, 2003 | 01:30 AM
Heatmaker's Avatar
Advanced Member
Aah, but you see when I gave you information to the Race track...it was actually helpful.
Miezere and CSI cannot answer the Waterpump question becasue they do not specialize on LT-1 engines. So it's better to find out from another source...
Old Nov 30, 2003 | 01:38 AM
stevil's Avatar
Re: Electric Waterpump installation notes
I wouldn't reuse the coolant. But yeah, fill it up when it's all back together, then start it and you'll need to bleed the system of air, might need to add some more coolant, etc. You'll get a low coolant light if it isn't full yet.
I probably filled it straight into the radiator to start the filling process, I forget. Since it will be empty, and cool, you can open that cap and use it to fill.
Here is the guide I used for Opti/WP
If you're doing an electric waterpump, I have some pics and info that might help ya. Most of that is for using parts of the old AIR system for the CSI install (harness, relay) not sure if you'd want to do that... but there is some CSI stuff at the bottom.
Draining the system of coolant is messy as hell btw. I had a big bucket but only half the coolant made it inside.
Old Nov 30, 2003 | 02:06 AM
Heatmaker's Avatar
Advanced Member
Re: Re: Electric Waterpump installation notes
Thanks!
Sergio
Jan 27, 2016 04:27 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
