electric waterpump on a daily driver? specifically a 383?
Old Jul 15, 2003 | 05:29 PM
thewinner's Avatar
anyone have a 383 with an electric water pump? specifically the csi?
im just wondering how you like it, cause im going to most likely need a new timing chain here and this is pretty much my only option.
anyones pump just suddenly stop working? recommend it over a stock one?
and is the p/n on the double roller chain, CLO-9-3100 thats a summit p/n
Old Jul 15, 2003 | 06:58 PM
94ZVert's Avatar
I have the CSI on my daily driven stoker. I'd recommend it.
Old Jul 15, 2003 | 07:54 PM
wicked_95z's Avatar
Im going to be using a CSI waterpump on my stroker when its done. Go to www.akmcables.com and they have a schematic that you can wire in a warning light to tell you when the pump fails and when you have a bad ground. Im definitely making use of it.
Old Jul 15, 2003 | 08:08 PM
97 RedSS's Avatar
Meziers for 2 yrs on my car w/o any problems as of yet..(knock on wood)
Cody
Old Jul 15, 2003 | 08:12 PM
Z95m6's Avatar
My friend has a CSI and it has stopped working on him 4 times causing the car to get hot. They are not worth it in my opinion that is why i went with the extreme duty chain.
Old Jul 15, 2003 | 08:13 PM
juicey's Avatar
I am also running the Meizere electric water pump on my 383ci LT1. No trouble as of yet...
Thanks,
Wes
Type_O_Negative_1320's Avatar
Mine has been fine so far...other than that one time, that is.
I don't know if the fuse holder that I had comes with the pump or not (I didn't install it), but mine melted and broke the connection between the pump and power. Not cool at all. Keep an eye on it and you should be fine...I'll be wiring up an idiot light to it at some point in the near future just to be safe.
EDIT: I'm running a CSI, by the way.
Old Jul 15, 2003 | 08:24 PM
TedH's Avatar
When I did my motor I just installed a new stock pump. I didn;t want to have to worry about it since I drive on the street.
Old Jul 15, 2003 | 08:27 PM
4drLT4's Avatar
Re: electric waterpump on a daily driver? specifically a 383?
Still running my Meziere after 2 years. Everything ok. By the way, I think that Cloyes P/N is: 3145 not 3100.
Old Jul 15, 2003 | 09:00 PM
thewinner's Avatar
hmm seems hit or miss really lol.
gotta get this worked out first http://web.camaross.com/forums/showt...hreadid=145967
Old Jul 15, 2003 | 09:13 PM
thewinner's Avatar
the electric should cool better at all rpm right? since it moves more water constantly than the stock does at redline?
damn......why the hell cant someone make a double roller work with the stock pump.
Old Jul 15, 2003 | 10:04 PM
red's Avatar
red
I have had my CSI on for two years with no problems.
Old Jul 23, 2003 | 10:58 PM
moreboost's Avatar
Still have my CSI in for 1 1/2yrs and still going strong!
The idiot light sounds like a good idea! Can someone post the link here?
Old Jul 24, 2003 | 08:09 PM
wicked_95z's Avatar
Just go to www.akmcables.com and look around and you will find one of the setups
Old Jul 24, 2003 | 11:13 PM
moreboost's Avatar
OK found it, heres the link for anyone else looking...
http://www.akmcables.com/mezinst2.jpg
Thanks Andrew! for the info....
